Quantcast
Philips 32pw9768 pt2
braincapers
Not as unhappy as I was much jiggering with the picture has improved things. It's still not so good on some of the cable channels (sport is often v bad). Does anyone know if I would be better off with Sky+?
One other the TV now has a nasty hum which is probably caused by some vibration as leaving on the back of the TV stops the noise for the duration of the lean! Obviously I'll be calling an engineer but has anyone else had anything similar?
