Philips 32PW9631 - any opinions?
Discussion in 'General TV Discussions Forum' started by cbemoore, Jul 25, 2002.
  1. cbemoore
    cbemoore
    May 16, 2002
    1,300
    38
    Esher
    +16
    I've just been offered a 2nd hand Philips 32PW9631. Its about 4 years old.
    Basic spec as follows:
    32" Widescreen
    100Hz, with 'Crystal Clear' enhancement
    Dolby Surround, with rear surround speakers
    Does anyone have any opinions on this TV? Any major problems to look for? And what would be a fair price?
    I've done a web search and looked through old posts on this forum, but can't find any info. Maybe its a rare model?
    Chris
  2. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    I looked in an old Philips catalog (Swedish 1995/1996) and it seems it is an early PALplus set (you might want to check that first).
    It is probably based on a BESIC/PROZONIC feature box that has a limited color resolution. This might be of importance, especially for DVD and video games. This is also true of many newer 100Hz sets though.
    I think you should look for the general ageing faults, and see how you like the character of the picture. The older 100Hz Philips sets tend to have a bit rough, softish picture.
    I haven't got much of a clue on the price... but given that it is fairly old by now you should not pay that much.
  3. MLS
    MLS
    Apr 7, 2005
    43
    London
    Chris - I bought one of these in 1996 (it was delivered and set up at half-time in the England vs Scotland match in Euro96!)
    I have to say it has given me 10 years of superb trouble-free service. A great picture, good features and the main reason why I haven't gone over to LCD yet!
    One 'feature' I did find more of a hindrence than a benefit was the Digital Noise Reduction, which resulted in shadow images when things moved, so I turned it off or set it to minimum.
    Otherwise, not a single complaint - ten years on and it still seems to offer a great picture. No idea what it's worth though. MLS
  4. MLS
    MLS
    Apr 7, 2005
    43
    London
    Actually, Zacabeb, the UK version wasn't PALplus. IIRC Philips used its own proprietry interpolation process to add in the extra lines in a letter box broadcast.
    The disadvantage was that interpolation is less accurate than PALplus, which I believe encodes the missing lines in the black bars, but very faintly.
    The advantage was that it also works on VCR inputs and non-PALplus broadcasts.
    It did, however, recognise PALplus signals, so whenever I switched over to C4 it automatically went into 14:9 mode. Not sure if C4 still broadcasts in PALplus as I only have a SKY+ feed now. MLS
