Philips 32PW9617 stand
C
colinbarber
Can any owners of a 32PW9617 measure the height of the stand and the distance between the shelves.
It appears that I would be unable to fit my Sky decoder, DVD player, VCR and Tivo under the TV without at least one of them being on the floor.
Does anybody know if another type of stand is available for this model?
L
lespaton
The distance from the floor to the underside of the stand is 17 inches. The two shelves are adjustable, the top has three positions, the bottom has two. With the top shelf in the highest position and the bottom shelf in the lowest the distances from the underside of the stand to the floor are...5 in, 7 in and 4 in.
You could drill additional locating holes for the shelf supports which would allow you to vary these dimensions, that is aside from the existing variations possible.
The only other option is a piece of AV furniture...IKEA ?
