Philips 32PW9576 yellow patch? 2 TVs
Discussion in 'General TV Discussions Forum' started by dsg, Jul 1, 2002.
  1. dsg
    dsg
    My philips 32pw9576 has a deep yellow/brown patch on right hand side which shows worst on a bright still picture (from my security camera) but shows faintly on all light pics (eg skies)
    Engineer called, no problem, tube faulty, received new TV.
    New TV, same problem but not quite as bad.
    Is this inherent with this model? Should I go for 3rd time lucky or try another make or model, any advice appreciated!
  2. Matthew Attoe
    Matthew Attoe
    Dec 8, 2001
    702
    Norwich
    +11
    got the same problem on 9607 stain down right-hand side and also on left hand side.
    if you check out my thread called something like "36pw9607 can you try a little experiment for me" i've detailed it all out there.
    Engineer came, and recommended a swap out too.
    have to wait and see.
    if it's not as bad, perhaps it doesn't affect all models and we might get a good one.
    Matthew
  3. dsg
    dsg
    Tried changing screen modes but yellow stain follows the bright area although more prominent the nearer it is to right side of screen!
