Philips 32PW9536 service menu problem
Discussion in 'General TV Discussions Forum' started by WeakestLink, Nov 26, 2004.
  1. WeakestLink
    WeakestLink
    I can't seem to get into the service menu using the matchline remote. I'm sure it should be 062596 i+ but I can't get anything to appear on the screen. I've tried it at all different speeds but nothing. Would it be a different code for this model?
    Any ideas would be appreciated.
    J
  2. WeakestLink
    WeakestLink
    Sorted...... the software version I have needs very specific (25ms) delays between presses - impossible by hand. Solution is to build a programmable infrared transmitter (component parts cost about 1.50 from Maplins) and run it from win98 PC serial port (software to do this is downloadable from web)
