Philips 32PW9527 Tilt Adjust
Discussion in 'TVs' started by pstables, Jan 5, 2004.
  1. pstables
    pstables
    Dec 4, 2002
    58
    Rossendale, Lancs, UK
    Hi all, in the January sales I picked up a Philips 32PW9527 ex display for £480 (I've had one before (which cost me £1000) so knew what to expext with Pixel Plus, etc).
    Very happy with the set but the only niggle is the right hand side of the picture is sloping downward.
    There is a tilt control in the setup menu but it doesn't make any difference at all.
    In the service menu there doesn't seem to be any way of adtusting the image tilt either (although there is an option to turn the tilt adjust on or off - tried both).
    Any suggestions?
    Paul
  2. pstables
    pstables
    Dec 4, 2002
    58
    Anyone - there must be some Philips Pixel Plus owners out there who could try the tilt adjustment for me and let me know what happens.
    Paul
  3. Gonkenobi
    Gonkenobi
    Hi Paul,
    I own a P+ 36PW9527, and I think I have the same problem with the right side of the picture bending downwards. From what I've read it has to do with the tube (Panasonic by the way).
    You are right, there is nothing in the service menu to adjust horizontal linearity. I tried with the tilt configuration in the setup and reduced but not eliminated the problem. Try reducing the brightness and contrast levels, it will help a bit.
    Regards
    Gonzalo
  4. secondmouse
    secondmouse
    Thanks for highlighting this. I was thinking of buying a £899.99 32PW9528 model from Comets but now I'll take a much closer look if it uses the same tube as PW9527. Sorry doesn't help you guys much!
  5. pstables
    pstables
    Dec 4, 2002
    58
    My original 32PW9527 did not have the same sloping problem, in fact I never noticed any geometry problems.
    It was unfortunate that it went to be fixed, they damaged the cabinet, went back to be fixed again, repairer went into receivership (Endeva), never got parts from Philips, didn't get TV back, got refund (the short version).
    Apart from that saga I was very happy with the picture of my original TV.
