Philips 32PW9527 Changing chanel
Discussion in 'General TV Discussions Forum' started by TonyD, Jul 30, 2003.
  1. TonyD
    TonyD
    Jun 8, 2003
    11
    4
    Surrey
    Has anybody else suffered the following problem :-
    set changes to AV1 ( cable box ) intermitantly or whenever P+ or P- buttons are used.
    Any suggestions for a cure that does not require the set being taken away by a service engineer ( I do not have the black bar problem and I do not want it either ), would be apreciated.
  2. AcidScan
    AcidScan
    Perhaps it could be your cable box... If it is sending the AVLink command via Scart 1 the TV will switch to EXT1... ;) ;)
  3. nig28
    nig28
    The symptom you describe sounds like it could be the painter chip, the main chip in the tv. If it is a A10E chassis then this is most likey, this number should be somewhere on the back of the tv near the model and serial number.
    Nigel
