Philips 32PW9509 Setup
Discussion in 'General TV Discussions Forum' started by john2303, Jul 14, 2004.
  1. john2303
    john2303
    Jul 2, 2004
    285
    Aberdeenshire
    +8
    My setup is as follows:
    32PW9509 TV
    Sony DVD Player
    Philips DVDR 70 Recorder
    Sky +
    The person that set the TV up has not set it up very well at all and I need some help urgently - please can someone out there tell me where all the scart leads etc need to go.
    Thanks in advance for your help
    john
  2. john2303
    john2303
    Jul 2, 2004
    285
    Aberdeenshire
    +8
    Really struggling here with this - would really appreciate some help.
  3. tutu
    tutu
    Apr 28, 2004
    2,223
    48
    +58
    It's not rocket science!
    Get the manuals out, or look at them before you install. Presumably the TV has 3 scarts, two are RGB.
    Connect the DVD player to the TV. Connect the Sky+ to the DVR. Connect the DVR to the TV. That should cover the scarts.
    Alternatively, you can connect the DVR to the Sky+ and connect the Sky+ directly to the TV.
    Take the aerial and plug into the Sky+. Then plug it into the DVR. Then the TV.
    That is, without looking at your specific models, a guess.. but probably right...
    nuff said really? :smashin:
