Philips 32PW9509 Problems
Discussion in 'General TV Discussions Forum' started by Wackojacko32, Jan 6, 2005.
  1. Wackojacko32
    Wackojacko32
    Jan 6, 2005
    239
    Pinxton, Derbys
    I purchased one of these from www.discountaudiovisual.com in December and have been having the all too familiar problems namely
    - white bar down centre of screen
    - black banding when panning
    - 'dirty' window syndrome
    - ghost effects even on 100hz digital scan
    It is some consolation, but not much, that these do not seem to be isolated problems from the number of posts I have read over the past couple of days.
    I do however seem to have a problem which has not been mentioned, as far as I can tell. When displaying large blocks of a single colour, particularly yellow, the result is a vertical stripe effect. It is not limited to any one source e.g. analougue, Cable and DVD's all show the same problem. It is worse on animated features, I suppose this is because of the uniformity of colours used, but have noticed it elsewhere also.
    Any thoughts would be appreciated.
    Wackojacko32
  2. warcow
    warcow
    I noticed "ghosting" on my pw328719 until I turned off Dynamic (or digital can´t remember) noise reduction. Worth a shot!
    (I also turned off sharpness)
    /Stefan
  3. Wackojacko32
    Wackojacko32
    Jan 6, 2005
    239
    Pinxton, Derbys
    Thanks for the reply Stefan. Didn't seem to make any difference tho.
