Philips 32PW9509 and progessive scan DVD?
Discussion in 'General TV Discussions Forum' started by Connal, Feb 4, 2005.
  1. Connal
    Connal
    Help!
    I'm using a Denon DVD2910 with the Philips TV. What's my best way to connect them? I only seem to have the option of using Scart, but does that pick up on the progressive scan capabilities of the DVD player?
    And is there any difference between Scart and RGB Scart cables which seem to go for more money?
    All help gratefully received by this newbie moron.
  2. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    The philips 9509 does not have component inputs,True progressive scanning will not be possible.Rgb scarts i believe are fully wired and able to carry a true rgb signal and are better quality.
  3. a2themutherk
    a2themutherk
    "RGB scart" usually means that the lead is only wired to carry pictures.So if you plugged your dvd into your tv using a scart like this you would only get pictures,no sound.The upside is better PQ than fully wired scarts which carry both audio and video.To get sound you would have to use the audio out jacks on the dvd to a spare input on a stereo amp.Hope this helps.
