Philips 32PW9308C Ghosting Problem
Discussion in 'Televisions' started by Midget W, Nov 20, 2004.
  1. Midget W
    Midget W
    Nov 14, 2004
    10
    Just set the beast up, along with my Humax PVR8000T, very bad ghosting, so checked the ariel signal on the humax and it said i had 51 one percent signal, yet my old 14 inch tv picture was excellent, howcome it has such an effected on the bigger tv? dvds look good though.
  2. red16v
    red16v
    Aug 20, 2004
    552
    +5
    I presume the Humax is a DTT receiver and as such can't give you 'ghosting' although it could clearly give you a lot of other very interesting picture distortions! Sounds like a video termination problem -try swapping over your scart input connections and see if it makes any difference ? regards, yt
    Unless of course you were saying that the analogue tv picture was ghosting and you were just using the Humax as some sort of signal strength indicator (?) in which case I take everything back ! regards, yt
