Philips 32PW 9509 Movie mode
Discussion in 'Televisions' started by WYSIWYG-UK, Apr 18, 2005.
  1. WYSIWYG-UK
    WYSIWYG-UK
    Hi all.
    I have been using Movie mode since i got the tele but i have started noticeing it gives a halo effect like pixel plus 2 does. i realise movie mode is pixel plus one but im sure i should not be seeing the same halo type effect on people.
    any ideas?
    thx
  2. PMF
    PMF
    Jan 22, 2004
    87
    +46
    I have the 9528 PP v1.5, I also use the movie plus mode and can confirm you do get the halo effect, I don't see much difference between Pixel Plus and Movie mode. I believe it reduces the effect but doesn'y completely eliminate it, so it should be less noticeable and less often but its virtually impossible to compare, because the effect is only very occasionally seen. I see it mostly with a vertical striped background such as railings and someone walking quickly by them. The problem is once you start to notice something you look for it and it becomes more noticeable.
