Philips 32PFL9632D & SKY HD - HDMI Issue
Discussion in 'Sky Digital TV Forum' started by 499520, Sep 1, 2007.
  1. 499520
    499520
    May 22, 2007
    88
    +19
    Hi Guys
    I'm having problems with the signal dropping out every 10 secs or so. HDMI lead OK on DVD player.
    Anyone else seen this issue???
    Works OK on component - any difference in Component V HDMI quality??
    Phil
  2. penna
    penna
    Mar 13, 2005
    232
    28
    Surrey, UK
    +31
    I've got the same issue with 32PFL9632D and Sky HD.
    I have tried a different cable, and have had a Sky engineer out with a replacement HD box and that did not work either.
    It would appear to be a problem with the TV though, seeing as though other people are having the exact same issue!! :( I can only think that it is a HDCP handshake problem.
    See http://www.avforums.com/forums/showpost.php?p=5411172&postcount=672 and http://www.avforums.com/forums/showpost.php?p=5413208&postcount=679.
    I have been on the phone to Philips support and they said they will get the tech people to ring me back (that was Tuesday - called them today and they never had my number, so they will ring me on Monday! :mad:). I will point them to this forum, if they don't already know about the issue...
  3. Smith2004
    Smith2004
    Mar 28, 2004
    1,574
    +187
    I have the same problem with the Philips 42PFL9632D. Let us know what Philips tell you.
  4. 499520
    499520
    May 22, 2007
    88
    +19
    Just spoke the Philips. this is a known software issue and a fix is expected mid October.
    They provided me with a reference and said a USB card would be sent to me in the post with the upgrade......
    Good news.........
    Phil
  5. fourier
    fourier
    Has anyone received the software update yet? I just spoke to Philips and initially they said they never heard of this issue, but then I pointed the representativ to this page and they are now sending me a software update on a USB stick to try.
    I was womdering if anyone has determined if this has fixed the SkyHD problems ?
    Cheers !
    Jon
  6. richie05
    richie05
    Aug 15, 2007
    114
    +11
    I have a PF9731 and get all the software updates for the telly from the philips support site. I wonder if you can't download it from there rather than waiting for them to post it out??
    Richie
  7. contraste
    contraste
    Sep 14, 2005
    1,554
    Marylebone, London W1
    +97
  8. penna
    penna
    Mar 13, 2005
    232
    28
    Surrey, UK
    +31
    I had this problem, and the latest software, as linked above, does indeed resolve it ;)
  9. 499520
    499520
    May 22, 2007
    88
    +19
    I've downloaded the latest update from the philips site and it resolved all the issues I had seen.
    HDMI is working fine....
  10. fourier
    fourier
    well, the USB fob turned up with new firmware...but it didnt fix the problem...I'm not convinced that the person I spoke to knew about the issue, and the firmware I got may have just been the latest version, but without any fixes in it...will keep waiting..............
  11. fourier
    fourier
    aha...just read lower down...will try the newer firmware and see...fingers crossed !
  12. fourier
    fourier
    new firmware - all fine !!
