Philips 32pf9986 Wall Plate(s) ??
Discussion in 'Philips TVs Forum' started by rnsdm001, May 13, 2005.
Tags:
  1. rnsdm001
    rnsdm001
    hello
    My question is, should I have recieved two wall plates for mounting to the wall or just the one?
    I recieved one wall plate and have hung my tv on the wall, but because ive only recieved one plate, the tv leans forward slightly.
    The tv does have 4 knobs on the back of it (2 at the top and two at the bottom). Im only using the two at the top
    Is this correct?
  2. CosmoKramer79
    CosmoKramer79
    You should only receive the one wall mount, the two knobs at the bottom are for the table stand!
  3. rnsdm001
    rnsdm001
    right, ok.
    so the tv is not supposed to face exactly straight forward
    its supposed to dip slightly
    While we are on the subject - the plate is visible once the tv is up - its quite ugly to say the least. Im goin to have to find a way to disguise the plate
  4. Phill_1981
    Phill_1981
    Feb 14, 2005
    1,571
    Woking, Surrey
    +44
    there should have been two caps in the box to put on the bottom 2 knobs to push the botton out a bit
  5. Phill_1981
    Phill_1981
    Feb 14, 2005
    1,571
    Woking, Surrey
    +44
    find them?
  6. rnsdm001
    rnsdm001
    Thanks Phil - found them - Wondered what they were!!!!!
    much better now!
  7. Phill_1981
    Phill_1981
    Feb 14, 2005
    1,571
    Woking, Surrey
    +44
    good good :thumbsup:
