Philips 32PF9986 & Slimline PS2
Discussion in 'Philips TVs Forum' started by Phill_1981, Sep 1, 2005.
Tags:
  1. Phill_1981
    Phill_1981
    Feb 14, 2005
    1,571
    Woking, Surrey
    +44
    When I hook up the PS2 to my 9986 LCD I get a 1" black border around the game image, is this normal with this screen? Why doesn't it fit the whole screen?
    (connceted be an IXOS scart lead)
    :thumbsup:
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    I take it you have tried the screen expansion button to full 16:9 setting. Should work. If you still have the border on this setting then try different picture settings within the PS2.
    Jimmy
  3. andrewfee
    andrewfee
    Apr 27, 2004
    3,066
    +500
    Yes, it's normal; the PS2's output doesn't fill the whole frame, however a lot of televisions hide the fact with "overscan."
    CRTs use a lot of "overscan" when displaying an image, which is why you usually don't see it on them. Overscan basically stretches the image beyond the physical dimentions of the screen, if that makes sense, effectively cropping as much as ~5% of the picture.
    On a CRT the bars would distort heavily as brightness etc changes, which is why it's used. On an LCD, you do not have these issues, so they display the full frame onscreen, rather than using a huge amount of overscan.
    With the PS2 it means you see borders, but with an Xbox, DVDs etc it means you're actually seeing ~5% more information onscreen.
  4. Phill_1981
    Phill_1981
    Feb 14, 2005
    1,571
    Woking, Surrey
    +44
    Cheers guys, glad its normal so I dont have to try sending one back to the shop!
  5. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    You know, I've been using my Playstation on the 9986 for 9 months and I never even noticed this! Shame on me...You can get rid of it nearly by using the 16:9 expand, but this distorts the picture a little.
    Jimmy
