philips 32PF9986 - Scart
Discussion in 'Philips TVs Forum' started by oldguy, Mar 7, 2005.
Tags:
  1. oldguy
    oldguy
    Feb 21, 2005
    42
    rotherham
    About to take the plunge and buy this like many others.
    Has anyone connected using "long" Scarts ?
    I've seen a couple of types at 10m, BUT am I likely to loose picture quality using long cables ?
    Can anyone recomment a brand ?
    thanks
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    This'll cost you! Check out the various suppliers..(www.tvcables.co.uk) and see what they've got...it'll need to be a good one...
    Jimmy
  3. sbheaven
    sbheaven
    Jan 20, 2005
    12
    I use 10 m scarts and RGBs. The scarts are about 10 years old and the cable is about 1.5cm in diameter. The RGB is a month old. I can notice that the RGB is slightly better than the SCART when playing a DVD. However SKY straight to the TV (and using the RGB output from the digibox) is in my view excellent.
    PS The SCARTS are not gold plated
  4. joker_zero
    joker_zero
    Dec 4, 2004
    222
    go to Lektropaks for long run cables - they will make them up to your requirement, so if you only need say 8.5 meters you are limiting the length of the run. Use thier Home Cinema or Pro grade cables. I have a SVideo from them at 10 meters running Sky+ to a projector and the quality really is pretty good considering the source and length of the run.
  5. oldguy
    oldguy
    Feb 21, 2005
    42
    rotherham
    thanks guys, that helps,
    NOW THEN !!! THE HARD PART -
    Getting hold of the 9986 !!!
    No-one has one ! ( for the right price )
    Anyone got one recently ? If so where from ?
