Philips 32pf9986 - How do I stop 'auto processing'
Discussion in 'LCD & LED LCD TVs' started by rnsdm001, May 13, 2005.
  1. rnsdm001
    rnsdm001
    hi
    Now i have the tv set to the settings provided by jimsan - and they work great.
    I have some other settings to watch the footy. Now when i have input the settings and everything is how i like and start to watrch footy, the tv trys to make the picture better by altering the settings i have entereded.
    If you go into the menu, you can see the yellow bars moving back and forth as it correct the picture........How do I stop it doing this?
    Ive turned smart Picture off !?
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Smart picture should be set at 'personal'. This'll hold your own settings quite well. If you turn the 'Active Control' off the TV still does a bit of processing for you. I have mine set at Min and, to be honest, this seems to control the TV less than the off setting! Weird.
    Jimmy
