Philips 32pf9986 . How do i check software version.
Discussion in 'LCD & LED LCD TVs' started by kumamoto, Mar 6, 2005.
  1. kumamoto
    kumamoto
    Sep 2, 2003
    1,100
    38
    Watford
    +17
    I have read various threads on the philips lcd tv and i know they say that by pressing 123456 will show you the system menu.
    I may be doing something wrong,but everytime i press these buttons it just changes the channel !!!
    Please help :mad:
    I suspect it is version 1.3 becuase it wont show apicture via component,but its not a problem becuase i have ordered a dvd player with HDMI.
    Many thanks for your input
  2. Dogboats
    Dogboats
    Feb 2, 2005
    63
    I think it's 123654 not 123456.
    HTH. ;)
  3. kumamoto
    kumamoto
    Sep 2, 2003
    1,100
    38
    Watford
    +17
    thanks dogboat, it is version 1.3.
    Have to get that hdmi enabled dvd player,still pictures from scart are brilliant!!
  4. kumamoto
    kumamoto
    Sep 2, 2003
    1,100
    38
    Watford
    +17
    is there any other gotchas with version 1.3 other than cant use component over DVI ???
  5. EffTee
    EffTee
    Jan 20, 2002
    196
    Bristol
    +5
    The differences between the firmware versions aren't well documented. The lack of component via DVI on 1.3 is the only significant one I'm aware of.
    I've said this before on these forums - if you get a 1.3 send it back. It's really surprising how many of them are still cropping up.
    EffTee
  6. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    EffTee,
    I was assuming that Kumamoto has had this set for a while. I haven't heard of anybody recieving a 'new' v1.3 for a while now...
    Jimmy
  7. kumamoto
    kumamoto
    Sep 2, 2003
    1,100
    38
    Watford
    +17
    can't take the player back, it was bought in november and taking it back is no option!!
    Since i am getting the marantz 9500 which is equipped with HDMI, i suppose i am fine.
    I am otherwise very happy with the TV
  8. EffTee
    EffTee
    Jan 20, 2002
    196
    Bristol
    +5
    Yeah, sending it back might be a problem. Having said that - my Dad paid for his in October and after it spent 2 months being "upgraded" he finally got a replacement in January :eek:
    If you're going DVI it's really not a problem.
    EffTee
  9. Dogboats
    Dogboats
    Feb 2, 2005
    63
    John Lewis in Welwyn Garden City sent me a 1.3 in the first week of February. After much messing about they replaced it but the replacement doesn't work (completely blank screen) although it was a 2.2.
    That one has to go back and, although I'm getting a refund, I'm gutted that I haven't got a working one. I love this TV and the ambilight feature is superb. I'll never be able to settle for a non-ambilight TV now. :(
  10. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    3rd time lucky Dogboats....
    Jimmy
  11. jonf
    jonf
    Sep 12, 2004
    240
    Sorry to be useless - but on the software version line - what part do i read to get the version? is it the number after the 'TX' or the number after the 'EU-' ?
  12. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    The one after the EU-
    Jimmy
  13. jonf
    jonf
    Sep 12, 2004
    240
    Thanks. Much appreciated. Now need to get it sorted - its on 1.3!!
