jimsan
Established Member
When you are watching a DVD through the DVI connection and you press the little PixelPlus button on the remote quickly you get the split screen thing showing the PP2 on and the PP2 off. You reckon the left hand side (PP2 off) is sharper???
Have a wee rub at your eyes and try again....
I have never tried the PS2 any other way than with the RCA connections. But I'm syre you could use the scart adapter that came with the PS2 and run it through Ext 3. Picture quality will be hellish, but it'll work. You really do have to have access to both Ext1 and 2, so your Ixos may be better suited to connecting something else (Sky to Recorder?) and purchase two rather slimmer scarts.
There is an option to turn on more OSD features, but this not only shows the volume bar but also places a permanent channel number in the top left corner! Dumb. Try it by going into the Menu. Click down to Setup, then across to General, Go down 5 clicks to OSD and select normal. You choose.
Jimmy
Jimmy
