Philips 32PF9986 Cable for Progressive Scan
Discussion in 'Cables & Switches' started by myersfan73, Sep 5, 2005.
  1. myersfan73
    myersfan73
    Jul 11, 2005
    4,000
    Whitehaven
    +268
    Hi, can anybody tell me what lead i need to connect a Philips 32PF9986 to a Denon HT550SD, to enable me to use Progressive scan playback. The Denon has Component conections the Philips has not! Which lead will get me from one to the other ? As progressive will only work via Component, is there a way around the connections. :lease:
