Philips 32PF9976
Discussion in 'LCD & LED LCD TVs' started by bigddd, Apr 2, 2005.
  1. bigddd
    bigddd
    Hi I was wondering if anyone could tell me if the Philips 32PF9976 is HDTV ready and will be able to recieve the sky hdtv signals when they start broadcasting :lease: ?
    Many thanks
  2. zoidy
    zoidy
    Mar 18, 2005
    693
    Surrey
    +53
    yes it is. I have one and it has a DVI socket that is HDCP enabled.
    I think it's a cracking TV for the price. It will receive both 720 and 1080 HDTV images.
    If the Sky box comes with a HDMI socket you just need to get a HDMI to DVI cable which are in abundance.
    Cheers,
    Pete.
