philips 32pf9976 pip problem
Discussion in 'LCD & LED LCD TVs' started by Leerock, May 10, 2005.
  1. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    Hi guys
    I think My dad s philips 32pf9976 got a problem with picture in picture function.
    I know it ain t got a double tuner but it doesnt show the image of a second input.
    Just teletext.
    Whenever i push the pip button i see a tv station on the left half
    and teletext on the right half.
    I couldn t get it to work with a second input.
    I ve tried to find some information in that crappy manual but nothing.
    Help please.
    Is this a firmware bug or sth?
    Oh
    And how can i check it s firmware version?
  2. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    anyone?
  3. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    OK Leerock,
    Check the firmware by punching in 123654 on the remote. The firmware no is included in the top line.
    Press the PIP. Use the remote cursor and select the right hand side. Press the teletext button on the remote. This should toggle it off and on. Press select when the RHS is selected and it'll tell you what it is recieving and will allow you to change inputs.
    This is how it all works on mine. (9986)
    Jimmy
  4. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    thanks jim
    I ll check that out next time i visit my dad :thumbsup:
