Philips 32PF9830 Stand Size
Discussion in 'Home Cinema Buying & Building' started by rythmix, Oct 24, 2005.
  1. rythmix
    rythmix
    Oct 22, 2005
    28
    If you own a 32PF9830, then this is the thread for you!!
    Could someone please measure for me, the gap between the bottom of the rotating stand and the bottom of the actual TV?
    In other words, how far from the surface is the bottom of the TV?
    Thanks!!!
  2. add46.88
    add46.88
    Aug 28, 2005
    978
    +22
    Does this tv have HDMI input???
    im getting confused with this one and the 32PF9986
  3. Bluestraw
    Bluestraw
    Apr 9, 2005
    290
    +19
    1) Distance is 59mm
    2) HDMI, DVI, Component - 3 unique HD inputs :)
