Philips 32pf9830 and Xbox360
Discussion in 'Philips TVs Forum' started by kas206, Mar 25, 2006.
Tags:
  1. kas206
    kas206
    Feb 20, 2006
    154
    28
    +33
    Hi. I just bought a Xbox360 and im having problems setting up the sound, Iv connected the xbox via component, and the sound using the phono cables. When ever i play games i dont hear any sound from the speakers, unless i switch to EXT3, I can hear the sound and obviously no picture.
    I read the Philips manual and it said the coaxial connection must be used when using the components. But the xbox only has a optical connection!
    Im sure there will many people here using the same setup, So please help if you can, I really dont want to use the scart, the picture is horrible!
    Thanks in advance.
  2. seaviewuk100
    seaviewuk100
  3. kas206
    kas206
    Feb 20, 2006
    154
    28
    +33
