B
beginner
Hi I am totally new to all this but in my wisdom or lack of it I have just ordered a Philips 32PF5520D but I am a little confused now. Can anyone tell me if this is the same as the 32PF5520D/10 or is there a difference? I paid £984 for this LCD at Curry's which to be honest I think is pretty good value in my limited knowledge. The reason I bought this is purely because I'd seen it in Comet for £1299 and rang Curry's who had it for the same but they matched their online price. I had a good look at the TV and thought it was pretty good but my knowledge is limited.
Can anyone suggest a bracket that I can wall mount this with bearing in mind it will be going on to a plaster board wall (into the stud). I also need some advice on the correct scarts and if it is possible to burt these into the wall and what I can get out of this TV. If anyone can help me on any of this I would be most indebted to you.
