Philips 30PF9975?
Discussion in 'Philips TVs Forum' started by kingsize, Jul 31, 2005.
Tags:
  1. kingsize
    kingsize
    Jul 16, 2004
    1,038
    +49
    I can get this TV for £999.00 - cheapest I have seen on the web is circa £1700.00.
    It's a TV for the bedroom - I would be connecting a Sony DVDR GX300 via component, and running a feed from Sky+ via RF.
    What I would love to know is - is this a good price?
    I know its not HD ready despite the resolution, but I can see it being a long time before SKY HD ( which I plan to get on release ) will be capable of running a second HD feed upstairs.
    Does anyone think this purchase is a good idea - would love some advice...
    Thanks.
  2. richard plumb
    richard plumb
    Jan 27, 2002
    14,479
    Windsor
    +1,046
    I have this set, and highly recommend it. I use it mostly for Sky, through a Tivo (so quality of feed is good but not great - Tivo adds a little noise)
    The philips does a great job of scaling the input to give a pseudo HD look to normal programs. DVDs look even better.
    Cost me £2k at John Lewis 18 months ago and worth every penny.
    Some foibles to take note of:
    - it has component in, but doesn't support interlaced video. OK if you have a progressive scan DVD player
    - it has a 720p screen but doesn't accept 720p over component. Does take 1080i though, so I have my fingers crossed that Xbox 360/Sky will be able to use that
    BTW, any idea what I'd get for my 18month old set, if I upgrade to HD ready? If its not very much, I'll just keep it.
  3. richard plumb
    richard plumb
    Jan 27, 2002
    14,479
    Windsor
    +1,046
    Hang on a mo. Cancel what I just said.
    It is a great set, but for £999 there are a few HD ready sets that should be at least as good, and a years newer tech.
  4. kingsize
    kingsize
    Jul 16, 2004
    1,038
    +49
    Thanks very much.
    Would you recommend it as a 2nd TV which in all likelihood will not have a hd input - once I have shy hd downstairs no doubt i will use the sky+ box upstairs.
    Do you have any issues with the screen?
    Thanks again
  5. richard plumb
    richard plumb
    Jan 27, 2002
    14,479
    Windsor
    +1,046
    I'd kill for it as a 2nd set. We are still a one TV household (ignoring the ancient Sony WF1 in the spare room gathering dust).
    IMO its one of the better LCD sets for non-HD stuff, simply because it does such a good job on the incoming signal to clean it up and increase the perceived resolution.
