philips 30pf9975 wall mount
natty
could someone please tell me if the 30pf9975 is vesa wall mount compatible. Looking at the rear, it appears no to be.
gringottsdirect
Yes, wall mounting kit supplied, as well as Basic Table Top Stand, Arch Table Top Stand optional at extra cost. :)
richard plumb
don't know if its 'vesa' compatible though - might be a proprietary mount (but its included) - you just need a drill and a spanner.
M
MOLSON999
I have just recieved my 30pf9975, which came with a wall bracket but no instructions of how to attach to wall. How do I attach it to the tv and wall? The bracket has 2 small 'light bulb' shaped holes but nothing to grip onto the tv. Do I have to unscrew something? Should i use 4 3inch screws to attach to wall?
M
MOLSON999
why do you need a spanner?
