philips 30pf9975 setup question
Discussion in 'Philips TVs Forum' started by IanW, Oct 16, 2004.
Tags:
  1. IanW
    IanW
    Feb 28, 2001
    1,612
    Wiltshire
    +151
    okay guys i have a question......
    I have just purchased a philips 30pf9975. Ok yes I would have liked a 32pf9986 but at £3,000 it was a little on the steep side for me (see my REAL stuff on my www). The 30pf9975 was only £1500 :clap: . I want to see an on screen indicator of the volume level, to do this I have to set the OSD to Normal as opposed to minimised. This provides the result that i want, however, this also provides the unwanted result of presenting the channel number in the top left hand side of the screen.
    How do I display the volume level on the screen but not have to permanently look at the channel id??? :confused: :lease:
    By the way I have tried :rtfm: but I cannot see anything?
    Thanks,
    Ian.
  2. LiquidB
    LiquidB
    May 25, 2004
    93
    +19
    You can't.
    The only way you can see the volume level when the OSD is minimum, is in the menu.
    You can't get rid of the channel number when the OSD is set to normal
