philips 30pf9975 question
Discussion in 'Philips TVs Forum' started by dingo8yobaby, Oct 7, 2004.
Tags:
  1. dingo8yobaby
    dingo8yobaby
    Jan 29, 2004
    2,030
    83
    a place that haz no reconz:(
    +296
    if you connect a pal prog dvd player to this screen, do you need to put prog scan on in the digital options of the tv or not?
  2. richard plumb
    richard plumb
    Jan 27, 2002
    14,450
    Windsor
    +1,044
    no
    Prog scan on the TV is a fallback mode from pixel plus. Its the most basic display mode.
    Just switch to the YpBr input via the input selector, and it should be fine.
