philips 30" LCD - power connection question
Discussion in 'LCD & LED LCD TVs' started by richard plumb, Jan 16, 2004.
  1. richard plumb
    richard plumb
    Jan 27, 2002
    14,349
    Windsor
    +1,028
    Can anyone help with either letting me know where the power lead goes in one of these, or linking me to a pic of the rear to work it out?
    I'm going to want white power cable, and it'll need to go in my current trunking, so I need to work out lengths - ideally before the TV is ordered/delivered.
    Also, anyone got one of these wall mounted? Any issues with room to plug in SCART leads etc?
  2. rab4169
    rab4169
    power lead is just a normal uk plug to 2 female ,just like on a radio or some games consoles, all i did was got a 5 meter extension to take 1 plug and ran this to where tv was going ,then when bought tv just pluged it in.
  3. richard plumb
    richard plumb
    Jan 27, 2002
    14,349
    Windsor
    +1,028
    ooh, nice and thin, so should go in my trunking nicely.
    Is it on the left or right side (as you look at the front of the TV)?
    Can you get those in long lengths though? I can't plug that in nearby the screen, and need to run the power at least 3m away to a socket.
  4. Davidedwards
    Davidedwards
    Power input is farthest left looking from the front.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    If its figure eight socket then shouldnt be a major prob maplins sell 5m fig 8 in black so someone will do white, i know as BOSE use em, where from i am not sure mate
  6. richard plumb
    richard plumb
    Jan 27, 2002
    14,349
    Windsor
    +1,028
    k, thanks.
    Black isn't perfect but it'll do. I'll put it in temp flat trunking and plaster and paint it anyway, so hopefully it'll just look like a bit of a bulge.
    Famous last words.
    Now just need the TV! Rang JL on Tuesday, lots of stock. Persuaded the wife on Saturday, no stock left!
