Philips 28PW6526 remote/ir problem
Discussion in 'TVs' started by Wavey, Nov 27, 2004.
  1. Wavey
    Wavey
    Help!
    I've got a Philips 28PW6526 TV, and recently the remote control began misbehaving i.e. it only works intermittently.
    I changed the batteries and also checked operation with a "one for all" type remote- this didn't work, so it looks like its the TV at fault.
    Can anyone suggest a likely cause or fix - I remember reading somewhere about faulty receiver circuitry which can easily be replaced.
    I'm handy with a soldering iron, but I couldn't see an easy way to even remove the case of the TV.
    The TV is about 5 or so years old so is out of warranty - could this be an expensive repair?
    Cheers....
