Philips 28" Widescreen Error! urgent help needed!
Discussion in 'TVs' started by FOCUZ, Jul 14, 2005.
  1. FOCUZ
    FOCUZ
    Hi guys, about a week ago my philips tv decided to not wanna work, what is happening is, when i switch it on its fine, then after like 5 mins it automatically goes to "EXT 1" then switches back to normal tv, then 2secs later back to EXT 1 repeated every 2 secs I have no idea how to stop this and Curry's are meant to be picking it up tomorrow but will cost £100. Does anybody know a solution before its taking away?
    Focuz. :lease:
  2. JayCee
    JayCee
    Jan 20, 2004
    20,353
    Lanarkshire
    +1,954
    Model no?
  3. FOCUZ
    FOCUZ
    dunno atm im in work!
  4. nig28
    nig28
    It sounds like the typical symtoms for a failing painter chip, cost about £130+ to repair.
    This fault is common if the set displays A10E on the back of the TV near the model number.
    Nigel
  5. FOCUZ
    FOCUZ
    Hi guys, the model number is: 28PW6826
  6. JayCee
    JayCee
    Jan 20, 2004
    20,353
    Lanarkshire
    +1,954
    This model is fitted with the A10E chassis and your symptoms are likely caused by the infamous "Painter" IC :thumbsdow
