Philips 28 PW630
Discussion in 'TVs' started by wesley99, Dec 18, 2004.
  1. wesley99
    wesley99
    Dec 18, 2004
    37
    I was just wondering if any one has any advice.
    I have a Philips 28PW widscreen TV which is now approx 5 years old.
    The problem with television is the response time when using the controls.
    I.E. When you switch the TV on it takes about 5mis to actually switch on and then if you change channel or turn up the volume etc it takes about 2mins. This makes using teletext etc impossible.
    The picture is fine & the TV sometimes it fixes itself and will be fine for a few days.
