Philips 23PF9946 DVI question?
Discussion in 'Philips TVs Forum' started by chrjul, Dec 10, 2004.
  1. chrjul
    I have purchased the 23PF9946 which has 2 scarts and a dvi which is for PC input. I am looking at getting the denon 1910 DVD player which has a DVI out. Will this work with the TV because the DVI connector on the philips only seems to be for PC input and you can't select the dvi as anything other then PC from the remote. I have asked this question of philips but alas no reply :mad: . Would appreciate any help as i'm fairly new to all this hi-tech stuff.
    cheers :)
