Philips 23PF5320
Discussion in 'LCD & LED LCD TVs' started by AndrewP84, Aug 19, 2005.
  1. AndrewP84
    AndrewP84
    May 30, 2005
    1,518
    41
    Essex
    +24
    Hi All,
    Im looking at getting a new tv for my bedroom as my old Daewoo 21" brick has packed up so I thought I would look into getting an LCD TV I have heard stories about playing PS2 games etc will burn out the screen is there any truth in this?
    Secondly I have been looking at the following LCD TV the Philips 23PF5320 this looks a great TV for a great price and this site seems quite good http://www.tvandvideodirect.com/product.php?xProd=1878.
    I got that by going on the pricerunner website, and it says its HD Ready/Upgradable im not sure which one, however the tvandvideodirect.com site does not give any details however with some searching I came across this site which gives more specifications:
    http://www.electricalscentre.com/acatalog/PHILIPS_23PF5320_FLAT_LCD_TV.html
    And if you click on "More Info" it takes you to a Philips type manual and it does not say its HD ready in there :(. And also it only has 1 scart :( but at least its RGB and I could buy a 3 in 1 scart thing any to get more connections if needed.
    Also the unbeatable site says its HD ready I think also but I may be wrong? - http://www.unbeatable.co.uk/CatalogueItem_29457.html
    I would like your opinions on the TV and it seems a fairly new model according to pricerunner, what does everyone think of it? :)
    Also if anyone could clear up for me if the TV is HD Ready/Upgradable I would be greatly appreciated :).
    Andrew
  2. ice9
    ice9
    Nov 29, 2005
    59
    11
    +6
    I bought the 23PF5320 on Sunday. I'm a bit of an impulse buyer which is probably not a good way to be with these type of purchases !
    Firstly it is HD Ready as the site claims.
    See my comment in the "phillips 23pf5320 lcd review and advice" thread.
    Opinions of this set are not great so far.
    I'm not really in a position to disagree with them until I get a better coax signal.
    DVD picture is good though. (Normal DVD-9 through scart).
    That's all I can offer right now.
