Philips 23-PF9946 DVI - HDCP compatible?
Discussion in 'LCD & LED LCD TVs' started by NBrice, Dec 6, 2004.
  1. NBrice
    NBrice
    Dec 6, 2004
    1,068
    +454
    With the recent news from Sky, and the likelyhood of HD-DVD only supporting HDCP too, I want to get a 23" LCD which is HDCP compatible via DVI.
    So far, I have found that only the Samsung 22" is confirmed to support HDCP via DVI in this size range.
    Does anyone know about the Philips 23"?
  2. NBrice
    NBrice
    Dec 6, 2004
    1,068
    +454
    Well, I have since found out that it fully supports DVI HDCP!
    So that's all good, but no component inputs :mad:
    However, it has a VGA input, and as I have the X2VGA box for my XBOX, that should mean no problems. And there's always RGB if the worst comes to it!
