Philips 17pf9946 setup
Discussion in 'Philips TVs Forum' started by davidblack, Dec 4, 2004.
Tags:
  1. davidblack
    davidblack
    i've just got a Philips 17pg9946 here in Sydney
    using it as both a computer monitor and tv
    using powerstrip i've got the monitor working in widescreen via vga but i can't get dvi working at all - which means i can't use PIP. :(
    my computer video card has a dvi-i dual link output and i got a dvi-d dual link cable to connect my computer to the philips but i just get a "No input signal" message when i try to switch to the dvi input
    Any help / advice would be much appreciated
    David
  2. davidblack
    davidblack
    bump
    any ideas???
