bodhi
Hi there,
I've been hunting around for a decent 15-17" screen for my bedroom. I've found loads of circa £200 units that look ok but i'm concerned that i'll be dissappointed with the picture quality. From what I can tell, the Philips 17PF9946 is a pretty good screen, and it's currently going for sub £300 which isn't too bad. However, I like to know exactly what i'm buying and i'm a little confused about the spec.
Apparently it's HDTV ready (Amazon, Dealtime etc. all say so), but although it does say on Philips' web site that it is a "High Definition LDC WXGA display", there appears to be no HDMI input, which leaves me wondering exactly how you could get a Hi Def signal into it without connecting it to a PC?
Can anybody possibly explain what the deal is with this?
Cheers,
Ben.
Cheers,
Ben.
