PHILIPS 14" TV/VIDEO COMBI HELP?
G
guysie
Hi help would be appreciated, I need to remove the back cover of this video combi, I have removed the 4 screws from the back cover but it will not fully come off.
The only thing that is left is a small star shaped screw any ideas would be appreciated.
This philips model is the 14pv there are a lot of these units around. :lease:
JayCee
Outstanding Member
The type of screwdriver you need is a "TORX" probably a T20 size.
G
guysie
Hi Jaycee thanks for your reply. :thumbsup:
Will removing this torx screw definately remove the back cove of this philips tv vcr combi?
JayCee
Outstanding Member
Yes, there are usually 6 Torx screws on Philips Combis, so it looks as though someone has replaced them with "Philips" type screws at some point?....or was there only 1 screw holding it together?
Why do you want to remove the back cover anyway?
G
guysie
I got this set brand new about 18 months ago, there were 4 philips screws and this one torx screw which is in almost where the back of the tube is.
The long plastic on /off button has come off, thats why i need to remove the back cover.
Thanks for your help.
Guy
Samsung & LG UK TV Prices 2023; Amazon Fire TV Cube; Calibration Tools of the Trade + AV news
