PHD8 & VGA
Discussion in 'Plasma TVs Forum' started by Demonio, Oct 23, 2005.
  1. Demonio
    Demonio
    Jul 1, 2005
    19
    Hi all! I'm (kinda) new here, but I've been reading on this great forum for months! :)
    I'm gonna purchase the Panasonic PHD8 Plasma soon although I'm not gonna buy any input boards, hdmi, dvi etc at this moment, as I cannot afford a DVD player (at least not the one I want) at the same time anyways. Also I will not buy a Scaler at this moment either because I'll rather wait to buy a good one than buying a crappy cheap one now. So..
    My question is: (The Cheap Solution :p)
    Via. the VGA board that is installed on the screen to start with. Can I stream DVD movies from e.g. my Laptop to my Plasma and use it as a sort of scaler by setting resolution to 1024x768. Will this work out or do I need some special grafic card to output via. the VGA cable? (laptop has radeon 9700pro)
    I was told this was possible (without any specific card) on a forum and I'd just like some of you experienced guys to confirm that it'll work out (before I go ahead and order!) :D
    Thanx a bunch! :)
    /David
  2. mine
    mine
    Feb 8, 2004
    128
    19
    88512 Mengen Germany
    with ease - just connect a good vga cable
    one caveat: the graphicchips of laptops are normally simple versions of the desktop
    chips and not very powerfull
    you will be able to get satisfying reproduction of DVDs - though HD material is out of reach and advanced tools like powerstrip to get 50 Hz and judderfree motion are not supported.
    best
    mine
