PHD8 over HDMI
Discussion in 'Plasma TVs Forum' started by blackeyepurple, Oct 18, 2005.
  1. blackeyepurple
    blackeyepurple
    I'm a bit dissapointed about the amount of picture noise (fuzz) I get over HDMI from my Samsung HD950 (I know not really a fitting DVD player for the screen). Last night I connected the player with a good quality scart and the picture noise just disapeared. Surely the HDMI should be at least as good as scart? remember giz posting a while back about the poor quality of picture on Pannys using digital connections. I have a component to 15 pin mini d-sub cable that will go in the PC input and have set the screen to component for this input but nothing displays. Am I being totaly thick or is it a PC only input and I need to buy the component box for the screen? Thanks for any help.
  2. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    no, it takes component. Did you set the dvd back to component output after trying the scart?
  3. dgc
    dgc
    May 1, 2003
    216
    It should work ok. I currently have component fed into the 15 pin input from my amp ( until the lumagen arrives - cheers Joe :smashin: ).
    When I first connected it up the input was set to RGB and the picture was there still but without colour. Switched it to component in the menu and all was well.
    Is your source definately outputting component?
    Is the cable wired correctly? - I mean is it definately component to 15 pin.
  4. blackeyepurple
    blackeyepurple
    Had the cable in use for component on a Tosh LCD (purchased for this in the first place) so I know the cable is goo. Went into the Sammys menu and set it to component (display also show this is progressive) and set the PC port on the Panny to component....still no picture. Gonna try a Cambridge Audio DVD with component tonight to rule out the player. It is a little strange though.
  5. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,607
    Norwich
    +1,026
    Ah, my mate has an HD950 and he says that the HDMI is awful, full of noise and just not very good.
  6. tjradiohead
    tjradiohead
    Jul 29, 2005
    4,036
    71
    +58
    What panel is that on?
  7. blackeyepurple
    blackeyepurple
    Well just wired up a Cambridge Audio DVD55 over component and WOW....this is the picture I expected when I got the PHD8! There is so much more detail and hardly any picture noise. It really is night and day compared to the Samsung. I hope the HDMI conector box is good for HD-DVD/Blue Ray or its been a complete waste of time and money getting this far with an HD Ready screen. One question (Giz you'll probably know this) why does the DVD55 player give a better picture when interlaced and worse when progressive? Fast motion becomes distorted on progressive but is perfect on interlaced. Is it that the panel changes the signal from interlaced to progressive? and is therefore processing the signal twice when the player is set to progressive. The LCD's I had before had a large improvement with a progressive signal from this same player with the same cable so i'm a little confused. Cheers.
  8. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    it's probably just that the panel does the job of deinterlacing better than the DVD.
  9. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,607
    Norwich
    +1,026
    He is using it on a Panasonic and on a Samsung, his trusty old Philips 963 is back on the main screen, again he bought the 950 for the hdmi upgrade! :rolleyes:
    What deinterlacer does the DV55 use?
    Probably just a case of it is not as good as the deinterlacer in the Panny screen simple as that.
  10. blackeyepurple
    blackeyepurple
    Thanks for all your help Giz/MEP.....good to know you guys are there with some answers :thumbsup: I have noticed although the picture is way better than the Samsung the DVD55 does give hairs/lines a staged effect that makes a curve look like a number of short lines are making it. This is not noticable from a distance but is close up......the Samsung did not suffer from this over HDMI but made all the graduations of shade very blocky so its better but still not perfect.....I feel a scaler comming on!
  11. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,607
    Norwich
    +1,026
    Or just buy a better dvd player with decent component outputs, the Philips 963 for £119 delivered from www.play.com will walk all over what you have at the moment.
  12. blackeyepurple
    blackeyepurple
    Cheers Giz.....have this at the moment: http://www.homecinemachoice.com/cgi-bin/displayreview.php?reviewid=3547 it got a really good review....you still think the Phillips is better? Not used to hearing anything positive about Phillips these days. Still....didn't stop me buying a Samsung product!
  13. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,607
    Norwich
    +1,026
    Well I still use a Philips player, have tried all the other so called top players from Denon, Meridian, Tag and Pioneer and don't think it can be beat for the money. I use mine SDI at the moment but component outs are very good too, and the Faroudja deinterlacing is really good too.
