PHD8 inputs/connections advice please
Discussion in 'Plasma TVs Forum' started by worz, Oct 29, 2005.
  1. worz
    worz
    Oct 20, 2005
    493
    +49
    Just wondered what the best way to connect the following equipment to my new baby.
    ATM I have Sky + via a scart to a JS RGB->VGA box, then into the vga port on the PHD8.
    I have the HDMI board installed and planned to buy a cheap Toshiba SD350E DVD to plug into that, just to tide me over until BlueRay or HD DVD's turn up.
    I want to get either an XBOX 360 or a PS3 too and SKY HD when it arrives.
    What would be the best most cost effective way of achieving this, Scaler not an option yet as my wallet is creeking badly :)
    Any ideas ?
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    I think you have the right idea with Sky+ into the VGA using a JS Tech converter. I believe the Xbox 360 won't have an HDMI output, only component or maybe a VGA so would need an appropiate board for that in slot 3. Sky HD and PS3 could be output to HDMI boards in slots 1 and 2. Hope this helps.
    Steve
  3. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    bnc component board is only about £60 and you would need RCA to BNC adapters for about a fiver as teh xbox component lead is RCA terminated.
  4. worz
    worz
    Oct 20, 2005
    493
    +49
    So running a BNC component cable up to the plasma would be a sensible idea, I am trying to get all the cables in i am likely to need before the plasterer comes. I either get em all in before or have a very unhappy Missus :nono:
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,992
    The Borders
    +3,599
    Hello worz
    If you want to be fully covered I'd install
    1 x HDMI cable
    1 x HD15 to HD15 'VGA' cable
    1 x 5BNC to 5BNC cable
    And some would also advocate a DVI cable in case you want Digital connectivity from a PC.
    Best regards
    Joe
  6. theo cupier
    theo cupier
    Sep 18, 2004
    1,670
    63
    Amersham, Bucks
    +113
    Sorry if this is a dumb question, but what does the 5BNC component cable give you over the 3 component cable board?
  7. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    I think it seperates out the horizontal and vertical sync
  8. worz
    worz
    Oct 20, 2005
    493
    +49
    Hi Joe, thanks for the reply :)
    I have had a look at the BNC component card that is available for the PHD8 and it only seems to have 3 BNC plugs ? I am very new to all this so am probably getting confused. could you explain for me a noob :)
    :oops: you can see i took a long time to reply, I didnt see Theo or MEP's replies :(
