Phd8 Dead!
Discussion in 'Plasma TVs Forum' started by blackeyepurple, Oct 27, 2005.
  1. blackeyepurple
    blackeyepurple
    Was just watching a DVD.....panel switched itself of....flashing red light :rolleyes: Switched it of and on again.....got a screen full of colours....then it switched off again and red light flashing! Now it switches on and I can get up all the on-screen menus up but no picture over scart or HDMI....its dead!
  2. blackeyepurple
    blackeyepurple
    :rotfl: I have to laugh.....I thought i'd finally found a good set and it dies on me in 2 weeks! I don't think anyone else has had this with there PHD8?
  3. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    at least you can laugh about it mate...it is a great screen, but sad you got a duff one...assume you've already sorted it with your supplier?
    ps* well done mods for deleting longy's trolling :thumbsup:
  4. blackeyepurple
    blackeyepurple
    I'll call AVSales in the morning....just means have the w/e without a TV :thumbsdow It is a great screen and I don' want anything else. I know I wont have any probs with AVSales replacing it....hope the next one is ok.
  5. AQU4RIUS
    AQU4RIUS
    Oct 16, 2005
    432
    +23
    home insurance ?
  6. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    i don't think so....it's not accidental damage
  7. blackeyepurple
    blackeyepurple
    Its only 2 weeks old....its faulty....its refund/replacement within 30 days.
  8. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Have you tried removing/reseating the cards? Well worth a try. The 1st bit reads like PSU failure, but if it comes on and stays on for menus, it can't be. You can select the inputs, presumably, just nothing there?
  9. blackeyepurple
    blackeyepurple
    Well I can get a bright pink screen over HDMI and no picture over component (VGA) and none from Freeview (Scart). I also dont get the menu's on the scart input.....only the VGA and HDMI. You can't remove the VGA as you know so I dont think its the boards. I got a very strange pattern of bright pink/green and white all over the screen and then a green bar dropped from top to bottom and it switched itself into safe (flashing red light) again. I spoke to Andrew at AVSales and he said it sounded terminal so they are replacing on Monday. Its the only one they have had do this so I guess I must be lucky! Something else I did notice when I first got the unit was that the stickers inside (one on the far right side fan top and one on the internal panel back) had hand written initials on them and the first unit I had only had a computer printed label on them.....wonder if it was re-worked in the factory for a similar problem and then ok'd by QC? just a thought.
  10. Dekim
    Dekim
    Feb 9, 2002
    301
    +5
    Hope with it been the last one it doesn't have stuck/dead pixels. Hopefully you'll be ok. You'll have to let us know.
    Deks
  11. blackeyepurple
    blackeyepurple
    Yeah....I had thought of that.....I'm obviously cursed so i'm sure it will have dead pixels and buzz like a mother.
  12. FlyingBig
    FlyingBig
    Apr 11, 2004
    545
    Lisburn
    If you don't mind be asking what was it better at doing than the pv500. Does it have no auto contrast and no horizontal line? That would just about make it perfect :)
  13. blackeyepurple
    blackeyepurple
    Dont think any PHD8's suffer with the horizontal line....still has the contrast/brightness issue though unfortunately.
