PHD8 - Connection Options
Discussion in 'Plasma TVs' started by nheather, Sep 23, 2005.
  1. nheather
    nheather
    Oct 6, 2004
    15,242
    Horsham, West Sussex
    +4,422
    Okay, if I go for PHD8 I will initially be connecting my Sky+ and DVD both using RGB SCART.
    My first thought is the connect them using
    >> JS Master SCART Controller and RGB>VGA Convertor to PC port
    Another option would be
    >> JS Master SCART Controller and RGB>Component Convertor to PC port
    This second option allows me to get a better DVD with component at a later date and using component switching in my Amp.
    Which would be considered the better approach for my current situation?
    Thanks,
    Nigel
