PHD8 component via VGA plug help!
Discussion in 'Plasma TVs Forum' started by Curry Monster, Aug 26, 2006.
  1. Curry Monster
    Curry Monster
    May 18, 2005
    5,455
    +258
    Just recieved a component to vga lead made by b-tech...
    For some reason only the green and red colours are working...however if i plug the blue lead into the red output i get blue where the red should be...doesnt this mean the leads ok??? am I doing something wrong and is there a setting i need to change??
    HELP!!
  2. Jase
    Jase
    Mar 16, 2001
    10,862
    United Kingdom
    +2,869
    In the Plasma's Setup menu have you told it the incoming signal is Component rather than RGB?
  3. Curry Monster
    Curry Monster
    May 18, 2005
    5,455
    +258
    erm yes...!
    I am sure i changed it! Thanks!
    Just got back from an overseas trip so stupid mode is still active!
