Timh
I have owned a Monolith for a couple of weeks now, and have found setting the phase not as easy as I thought it would be
The subwoofer is on the same wall as my main speakers but in a corner.
I have just set the phase playing Queens "One year of love" as this track has a slow repetitive base thump.
I started at 0 deg which is what it has been setup at since it was first installed.
At 0 deg I found it far to boomy but then moving to 180 deg I found that the base from the subwoofer vanished
I then set it midway at approx 90 deg which seemed to be the best compromise (but with less base).
Have I done this correctly?
All speakers set to small with freq being handled my my amp set to 80Hz.
