Phase checking- continuity test ok?
Discussion in 'Home Cinema Speakers' started by nathan_silly, Sep 23, 2003.
  1. nathan_silly
    nathan_silly
    Since I've moved bits 'o kit about (front three are now biamped) I want to double check phase & correct channel connection- I've got 6 speaker cable runs, and six phono leads for the front three alone! The cable mess is a bit of a nightmare :eek: so would it be possible to use a electrical meter on continuity test?
    Have one probe on + on the speaker terminal, with the other end on the phono lead that's connected to the MC-1?
    I'm pretty sure I've wired everything correctly, but would like to check.:laugh:
  2. rOAdeh
    rOAdeh
    Jan 24, 2003
    602
    Winchester
    +5
    There's phase tests on some THX optimiser discs (i think R2 T2 Ultimate Edition has it) for a simpler version of what you want but i'm not sure if that's sophisticated enough for you :)
