Phantom PVR With A Toshiba RDXS32
Discussion in 'Blu-ray & DVD Players & Recorders' started by dlaf42, Jun 27, 2004.
  1. dlaf42
    dlaf42
    Jun 27, 2004
    11
    Gateshead
    Hi all
    Can anyone with both of these please help me to get them working....i have followed the instructions but no can do the toshiba just turns on then off...
    i have my sky going from rgb scart to AV2 on the toshiba..then i have the phantom in Vcr scart of sky,then a scart from av1 on toshiba to rgb in on tv.
    i set the program planner to auto view it turns over sky then tries to set toshiba but nothing.
    Can anyone please help me as i am going mad here. :mad:
  2. cheeseman
    cheeseman
    Had the same problem. One of two things cured it. I figured that the PVR may be sending the signals before the tosh had powered up, so when you set up "channel select" on the PVR (button 2), i had it to beam the "HDD" signal (from the tosh's remote) a couple of times. I figured that this signal was a bit of a 'nothing' signal as far the operation of the PVR. I would also say to read the instructrions in the PVR manual and leave off the digibox for 10 mins between efforts. Works fine now. Good luck!
