Phantom Menance R1 or R2
Discussion in 'Movie Forum' started by IanW, Jul 24, 2001.
  1. IanW
    IanW
    Feb 28, 2001
    1,652
    Wiltshire
    +164
    So which one are people buying??????
  2. einpagu
    einpagu
    Region 1
    BR, Per-Anders.
  3. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    Neither - I thought it was rubbish
  4. TJSMANGINA
    TJSMANGINA
    i thought it was crap to but if i had to get a copy region 1 mate.that way you know your getting the best copy lol.
  5. YETi
    YETi
    Best copy? On what grounds? As far as I'm aware R1 and R2 are identicle bar more TV lines on R2 and it's released a day early!
    90% of the time I go for R1 but in this case I believe R2 version is the better option.
  6. Ian Cox
    Ian Cox
    I am going for R2 for the same reasons as mentioned before, they are going to be identical. Also the R2 version is released a day before the R1 version.
    Thats my view on it anyway
  7. Blade
    Blade
    I'm actually going to buy the R4 and the R1 and compare them. Then keep the best one.
  8. Nike
    Nike
    Feb 27, 2001
    667
    bournemouth, UK.
    +20
    That'll be down to the difference between PAL & NTSC.
    I think due to the conversion perocess, PAL runs about 3% faster.
    (Just don't ask me to explain it :confused: )
    I did read a really good explanation on this BB, can't remember the poster though.
  9. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    In my experience this R1 / R2 which is best NTSC or PAL is a red herring.
    There is alot more to this quality lark that standard differences. The quality of print being the major differnce in my book. Just look at the fifth element example, no one is going to tell me that they didn't come from different quality / generation prints. Braveheart is another example, only in the other dirrection.
    The only way to tell is buy both versions and try them.
  10. Confucius
    Confucius
    Feb 1, 2001
    2,151
    Oxford
    +132
    PAL runs 4% faster - a 24 fps film runs at 25 fps, equating to runtimes 2.4 minutes faster for every hour of film.
  11. IanW
    IanW
    Feb 28, 2001
    1,652
    Wiltshire
    +164
    One thing that I did notice was that on PLAY247 they were showing that the R1 is 4 minutes longer than the R2 :eek: Is this the case?
  12. IanW
    IanW
    Feb 28, 2001
    1,652
    Wiltshire
    +164
    Surely this is a bit costly :eek:
    :eek:
  13. HeadBanger
    HeadBanger
    Sep 22, 2000
    2,273
    116
    Ashingdon
    +511
    Region 4. I want the quality of PAL at a reasonable price.
  14. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,611
    Somewhere in South Yorkshire
    +6,154
    Although there is a theoretical improvement in video quality of PAL over NTSC, generally the differences are small and much less than the differences that can arise during the transfer/mastering process.
    Typically, R2 titles have many more languages and/or subtitles on them which eats into the bandwidth that might otherwise have been used for picture. In some cases (Titan AE) you get DTS on R1, missing from R2.
    Also, anyone who uses progressive scan will, at present (skyworth excepted) get a better presentation from an NTSC item than a PAL one.
    Mainly for this last reason, I tend to favour R1. Unless, of course, there is some other benefit of R2 eg the right aspect ratio (eg Raw Deal, Austin Powers1) or a better version of the film (Austin Powers1 again).
    In the case of TPM, I'll probably go R1.
  15. Dirk 2
    Dirk 2
    Variations in runtimes as follows:
    Original Film Runtime/NTSC DVD Runtime
    Approx. PAL DVD Runtime
    83 minutes 80 minutes
    90 minutes 86 minutes
    100 minutes 96 minutes
    110 minutes 106 minutes
    120 minutes 115 minutes
    130 minutes 125 minutes
    140 minutes 134 minutes
    150 minutes 144 minutes
    160 minutes 154 minutes
    170 minutes 163 minutes
    180 minutes 173 minutes
    190 minutes 182 minutes
    Hope that helps a few folk out.
  16. HeadBanger
    HeadBanger
    Sep 22, 2000
    2,273
    116
    Ashingdon
    +511
    The picture quality of PAL and NTSC is probably similar although PAL does (potentially) have greater line resolution.
    It's the 'juddering' on NTSC caused by the pull down that I don't like.
    www.dvdfile.com/news/special_report/spotlight/3_2_pulldown.htm
    Some people just don't notice it but I (unfortunately) do. Threrfore, I much prefer the smooth presentation of PAL......
