PH7-ISCAN-VGA-Problems!
Discussion in 'Plasma TVs Forum' started by Claus, Mar 10, 2005.
  1. Claus
    Claus
    I'm still waiting for the terminal cards for my 42PH7 so I'm using the VGA output on the iScan HD+ straight into the VGA input on the PH7.
    In some scenes the pictures turns brighter, then it quickly goes down to correctl brightness.
    Does anyone know what the problem may be?
    Also, I can't seem to get a picture on the screen when I'm sending a DVI signal to the iScan HD+. It works with component. The output is always VGA (component).
    Thanks!
    Claus
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Prob. 2 is easy, the iscan does not output DVI inputs on analogue, it's not allowed to by HDCP. Prob. 1 may be the PHD7 bug, usually only noticeable in the black bars of anamorphic films. They don't do this on DVI you will be glad to know.
  3. Claus
    Claus
    Hey MAW,
    Thanks!
    Bug??? Can you give me some more info on this bug?
    Will it be visible on the component/S-Video/Composite card?
    Claus
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Not much more to say on the bug, not all screens do it, it was 1st noticed on US versions on s-video. Mine doesn't do it on component, but does on s-video on the same card. It does on VGA with the iscan, but I don't notice with a JS box. It's pretty weird. It definitely does not do it on DVI.
